A limiting absorption principle for scattering problems with unbounded obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Methods in the Applied Sciences Année : 2001
A generalized mode matching method that applies to a wide class of scattering problems is developed in the time harmonic two-dimensional Helmholtz case. This method leads by variational means to an integro-differential formulation whose unknown is the trace of the field on an unbounded one-dimensional interface. The well-posedness is proved after a careful study of the rather original functional framework. Owing to a fundamental density result--based upon some properties of a singular integral operator similar to the Hilbert transform--the limiting absorption principle related to this original formulation is established. Finally, two other situations are emphasized. Copyright © 2001 John Wiley & Sons, Ltd.
hal-01008796 , version 1 (17-06-2014)
Anne-Sophie Bonnet-Ben Dhia, Axel Tillequin. A limiting absorption principle for scattering problems with unbounded obstacles. Mathematical Methods in the Applied Sciences, 2001, 24 (14), pp.1089--1111. ⟨10.1002/mma.259⟩. ⟨hal-01008796⟩
113 Consultations
0 Téléchargements
