An Original Approach to Mode Converter Optimum Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Microwave Theory and Techniques Année : 1998
Jean-Michel Krieg
  • Fonction : Auteur
Eric Giguet
  • Fonction : Auteur
An original method of shape optimization has been developed to improve high-power high-frequency transmission lines' performances. This method is based on the coupling coefficients equations, for which general expressions are given. It makes use of numerical methods such as steepest descent associated to adjoint state technique. The results obtained on several types of components demonstrate the pertinence of this method
Fichier non déposé
hal-01010737 , version 1 (20-06-2014)
Éric Lunéville, Jean-Michel Krieg, Eric Giguet. An Original Approach to Mode Converter Optimum Design. IEEE Transactions on Microwave Theory and Techniques, 1998, 46 (1), pp.1-9. ⟨10.1109/22.654916⟩. ⟨hal-01010737⟩
154 Consultations
0 Téléchargements
