Strategies to learn computationally efficient and compact dictionaries
Dictionary learning is a branch of signal processing and machine learning that aims at expressing some given training data matrix as the multiplication of two factors: one dense matrix called dictionary and one sparse matrix being the representation of the data in the dictionary. The sparser the representation, the better the dictionary. However, manipulating the dictionary as a dense matrix can be computationally costly both in the learning process and later in the usage of this dictionary, thus limiting dictionary learning to relatively small-scale problems. In this paper we consider a general structure of dictionary allowing faster manipulation, and give an algorithm to learn such dictionaries over training data, as well as preliminary results showing the interest of our approach.
