RNS Modular Multiplication through Reduced Base Extensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper describes a new RNS (residue number system) modular multiplication algorithm, for finite field arithmetic over Fp, based on a reduced number of moduli in base extensions with only 3n/2 moduli instead of 2n for standard ones. Our algorithm reduces both the number of elementary modular multiplications EMMs and the number of stored precomputations for large asymmetric cryptographic applications such as elliptic curve cryptography or Diffie-Hellman (DH) cryptosystem. It leads to faster operations and smaller circuits.
article_asap2014.pdf (210.49 Ko) Télécharger le fichier
slides-asap.pdf (1.24 Mo) Télécharger le fichier
Format : Autre
hal-01010961 , version 1 (21-06-2014)
Karim Bigou, Arnaud Tisserand. RNS Modular Multiplication through Reduced Base Extensions. ASAP - 25th IEEE International Conference on Application-specific Systems, Architectures and Processors, Jun 2014, Zurich, Switzerland. pp.57-62, ⟨10.1109/ASAP.2014.6868631⟩. ⟨hal-01010961⟩
771 Consultations
814 Téléchargements
