An energy-consistent depth-averaged Euler system: derivation and properties. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series B Année : 2015
In this paper, we present an original derivation process of a non-hydrostatic shallow water-type model which aims at approximating the incompressible Euler and Navier-Stokes systems with free surface. The closure relations are obtained by a minimal energy constraint instead of an asymptotic expansion. The model slightly differs from the well-known Green-Naghdi model and is confronted with stationary and analytical solutions of the Euler system corresponding to rotational flows. At the end of the paper, we give time-dependent analytical solutions for the Euler system that are also analytical solutions for the proposed model but that are not solutions of the Green-Naghdi model. We also give and compare analytical solutions of the two non-hydrostatic shallow water models.
euler_av_num_final.pdf (586.09 Ko) Télécharger le fichier
hal-01011691 , version 1 (24-06-2014)
hal-01011691 , version 2 (22-08-2016)
Marie-Odile Bristeau, Anne Mangeney, Jacques Sainte-Marie, Nicolas Seguin. An energy-consistent depth-averaged Euler system: derivation and properties.. Discrete and Continuous Dynamical Systems - Series B, 2015, 20 (4), pp.28. ⟨hal-01011691v2⟩
500 Consultations
543 Téléchargements
