Property and Lighting Manipulations for Static Volume Stylization Using a Painting Metaphor - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2014
Although volumetric phenomena are important for realistic rendering and can even be a crucial component in the image, the artistic control of the volume's appearance is challenging. Appropriate tools to edit volume properties are missing, which can make it necessary to use simulation results directly. Alternatively, high-level modifications that are rarely intuitive, e.g., the tweaking of noise function parameters, can be utilized. Our work introduces a solution to stylize single-scattering volumetric effects in static volumes. Hereby, an artistic and intuitive control of emission, scattering and extinction becomes possible, while ensuring a smooth and coherent appearance when changing the viewpoint. Our method is based on tomographic reconstruction,which we link to the volumetric rendering equation. It analyzes a number of target views provided by the artist and adapts the volume properties to match the appearance for the given perspectives. Additionally, we describe how we can optimize for the environmental lighting to match a desired scene appearance, while keeping volume properties constant. Finally, both techniques can be combined. We demonstrate several use cases of our approach and illustrate its effectiveness.
volume_stylization-tvcg_Klehm2014.pdf (1.58 Mo) Télécharger le fichier
volume_stylization-tvcg_Klehm2014.mp4 (145.63 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-01016279 , version 1 (29-06-2014)
Oliver Klehm, Ivo Ihrke, Hans-Peter Seidel, Elmar Eisemann. Property and Lighting Manipulations for Static Volume Stylization Using a Painting Metaphor. IEEE Transactions on Visualization and Computer Graphics, 2014, pp.13. ⟨10.1109/TVCG.2014.13⟩. ⟨hal-01016279⟩
389 Consultations
300 Téléchargements
