Robust algebraic Schur complement preconditioners based on low rank corrections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
In this paper we introduce LORASC, a robust algebraic preconditioner for solving sparse linear systems of equations involving symmetric and positive definite matrices. The graph of the input matrix is partitioned by using k-way partitioning with vertex separators into N disjoint domains and a separator formed by the vertices connecting the N domains. The obtained permuted matrix has a block arrow structure. The preconditioner relies on the Cholesky factorization of the first N diagonal blocks and on approximating the Schur complement corresponding to the separator block. The approximation of the Schur complement involves the factorization of the last diagonal block and a low rank correction obtained by solving a generalized eigenvalue problem or a randomized algorithm. The preconditioner can be build and applied in parallel. Numerical results on a set of matrices arising from the discretization by the finite element method of linear elasticity models illustrate the robusteness and the efficiency of our preconditioner.
RR-8557.pdf (601.67 Ko) Télécharger le fichier
hal-01017448 , version 1 (03-07-2014)
  • HAL Id : hal-01017448 , version 1
Laura Grigori, Frédéric Nataf, Soleiman Yousef. Robust algebraic Schur complement preconditioners based on low rank corrections. [Research Report] RR-8557, INRIA. 2014, pp.18. ⟨hal-01017448⟩
711 Consultations
931 Téléchargements
