The Selection Procedure of Diagnostic Indicator of Suspension Fault Modes for the Rail Vehicles Monitoring System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The monitoring system of a rail vehicle and track has been developed under the project MONIT - Monitoring of Technical State of Construction and Evaluation of its Lifespan. The main subsystem of a rail vehicle being the object of on-line monitoring is the suspension. The principle of operation of the monitoring system is based on the statistical analysis of acceleration signals. The selection procedure of damage-sensitive parameters of signals is introduced. In order to improve suspension condition assessment, selected parameters are analysed in multidimensional space. As a result, a new diagnostic indicator is analysed - Euclidean metric between reference point (nominal state) and a point representing current measurement (condition). The proposed fault detection method was used for analysis of recorded data during an experiment on wagons with suspension damages.
0372.pdf (623.64 Ko) Télécharger le fichier
hal-01020334 , version 1 (08-07-2014)
  • HAL Id : hal-01020334 , version 1
R. Melnik, Bogdan Sowiński. The Selection Procedure of Diagnostic Indicator of Suspension Fault Modes for the Rail Vehicles Monitoring System. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020334⟩
175 Consultations
310 Téléchargements
