Reconstruction of Impact on Composite Airfoil Segment Using Piezoelectric Sensors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The presented study focuses on structural health monitoring technique with the goal to predict induced damage and assess the residual strength of impacted structure. Herein, the primary problem of impact force reconstruction is investigated on an airfoil segment (part of a propeller blade for a large fan) made of laminated composite with attached piezoelectric transducers. The segment is made from carbon textile using RTM technology. The reconstruction is based on deconvolution method and transfer functions. The efficiency of the proposed approach is tested for all impact locations used to calibrate the system, and also on several additional locations. The interpolation of transfer functions is used to increase the accuracy of the reconstruction.
0428.pdf (1.44 Mo) Télécharger le fichier
hal-01020395 , version 1 (08-07-2014)
  • HAL Id : hal-01020395 , version 1
Robert Zemčík, Jan Bartošek, Zuzana Lašová, Tomáš Kroupa. Reconstruction of Impact on Composite Airfoil Segment Using Piezoelectric Sensors. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020395⟩
125 Consultations
146 Téléchargements
