Nonlinear Acoustic Imaging of Structural Damages in Laminated Composites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper describes the application of nonlinear acoustic techniques recently reported in scientific literature for imaging of structural damage in a laminated composite plate. The techniques that have been considered include the local defect resonance technique and the second harmonic imaging technique. The tests are performed on a carbon fiber/epoxy laminated composite plate with barely visible impact damage that was generated in an impact test. The extent of damage is characterized by vibrothermography prior to nonlinear acoustic tests. The paper discusses theoretical background and experimental setup for each measurement technique.
0355.pdf (777.94 Ko) Télécharger le fichier
hal-01021069 , version 1 (09-07-2014)
  • HAL Id : hal-01021069 , version 1
Lukasz Pieczonka, Andrzej Klepka, Wieslaw J. Staszewski, Tadeusz Uhl. Nonlinear Acoustic Imaging of Structural Damages in Laminated Composites. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021069⟩
170 Consultations
358 Téléchargements
