Probabilistic Damage Detection Based on Large Area Electronics Sensing Sheets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yao Yao
  • Fonction : Auteur
Reliable early-stage damage detection and characterization requires continuous sensing over large areas of structure. The limitations with current sensing technologies lies in the fact that they either have high cost and insufficient spatial resolution, or rely on complex algorithms that are challenged by varying environmental and loading conditions. This paper addresses the need for direct sensing where anomalies are sensed at close proximity through a dense array of sensors, and proposes one approach for sensor network design. This approach is directly applicable to innovative sensing sheet based on large area electronics (LAE), which enables practical implementation of dense arrays of sensors. However, although the sensors are densely spaced in the sensing sheet, there are still some non-instrumented spaces between them and these spaces are not sensitive to damage. In this research, a probabilistic approach based on Monte Carlo (MC) simulations is researched to determine the probability that damage of certain size that occurs within the area covered by the sensing sheet can be detected with a given sensor network. Based on these Probability of Detection (POD) functions, it was possible to assess the reliability of sensing sheets for crack detection and to establish general principles for the design of sensing sheets.
0107.pdf (989.32 Ko) Télécharger le fichier
hal-01021208 , version 1 (09-07-2014)
  • HAL Id : hal-01021208 , version 1
Yao Yao, Branko Glisic. Probabilistic Damage Detection Based on Large Area Electronics Sensing Sheets. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021208⟩
96 Consultations
136 Téléchargements
