Development of Wireless Ultrasonic Propagation Imaging System for In-Situ Aircraft Inspection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently, laser ultrasonic propagation imaging (UPI) system has been greatly increased the attention of researchers for structural health management (SHM) application. The system has shown the promising results in the damage diagnosis of aircraft structures. However, the inspection was conducted in the experimental laboratory on a structure, which has been dissembled from an aircraft, which is not practical for the in-situ and large-scale aircraft structure inspection. This paper presents a wireless UPI system to realize the in-situ aircraft structure inspection. The system consists of a high-speed laser ultrasonic scanning system, a preamplifier-integrated piezoelectric (PZT) sensor network, an embedded wireless ultrasonic device (WUD), and a ground SHM system. In this work, four 8-channel analog multiplexers were used to connect the sensor nodes, which were installed along the webs of an aircraft, to the WUD with an integrated four-channel 12-bit analog-to-digital converter (ADC). The maximum sampling frequency of the ADC is 80 MHz. The WUD has an integrated Wi-Fi modem (802.11b/g/n). As further work, the UPI system will perform the inspection on a desired area with a selected local sensor node. Then, the acquired ultrasound will send to the ground SHM system to process for damage evaluation.
0328.pdf (630.4 Ko) Télécharger le fichier
hal-01021240 , version 1 (09-07-2014)
  • HAL Id : hal-01021240 , version 1
See Yenn Chong, Manish Man Shrestha, Jung-Ryul Lee. Development of Wireless Ultrasonic Propagation Imaging System for In-Situ Aircraft Inspection. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021240⟩
172 Consultations
213 Téléchargements
