Dense Semi-Rigid Scene Flow Estimation from RGBD images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Scene flow is defined as the motion field in 3D space, and can be computed from a single view when using an RGBD sensor. We propose a new scene flow approach that exploits the local and piecewise rigidity of real world scenes. By modeling the motion as a field of twists, our method encourages piecewise smooth solutions of rigid body motions. We give a general formulation to solve for local and global rigid motions by jointly using intensity and depth data. In order to deal efficiently with a moving camera, we model the motion as a rigid component plus a non-rigid residual and propose an alternating solver. The evaluation demonstrates that the proposed method achieves the best results in the most commonly used scene flow benchmark. Through additional experiments we indicate the general applicability of our approach in a variety of different scenarios.
Mots clés
proof.pdf (586.78 Ko) Télécharger le fichier
hal-01021925 , version 1 (09-07-2014)
Julian Quiroga, Thomas Brox, Frédéric Devernay, James L. Crowley. Dense Semi-Rigid Scene Flow Estimation from RGBD images. ECCV 2014 - European Conference on Computer Vision, Sep 2014, Zurich, Switzerland. ⟨10.1007/978-3-319-10584-0_37⟩. ⟨hal-01021925⟩
674 Consultations
699 Téléchargements
