Strategies for Contiguous Multiword Expression Analysis and Dependency Parsing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we investigate various strategies to predict both syntactic dependency parsing and contiguous multiword expression (MWE) recognition, testing them on the dependency version of French Treebank \cite{abeille:04}, as instantiated in the SPMRL Shared Task \cite{spmrl:st:2013}. Our work focuses on using an alternative representation of syntactically regular MWEs, which captures their syntactic internal structure. We obtain a system with comparable performance to that of previous works on this dataset, but which predicts both syntactic dependencies and the internal structure of MWEs. This can be useful for capturing the various degrees of semantic compositionality of MWEs.
main_depmwe-flatreg.final.pdf (95.5 Ko) Télécharger le fichier
hal-01022415 , version 1 (10-07-2014)
  • HAL Id : hal-01022415 , version 1
Marie Candito, Mathieu Constant. Strategies for Contiguous Multiword Expression Analysis and Dependency Parsing. ACL 14 - The 52nd Annual Meeting of the Association for Computational Linguistics, Jun 2014, Baltimore, United States. ⟨hal-01022415⟩
316 Consultations
419 Téléchargements
