Dispersion-Corrected Stabilization Diagrams for Model Order Assessment in Structural Identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study aims at overcoming some of the inconsistencies of stabilization diagrams, by applying a novel dispersion analysis framework that relies on the effective modal decomposition of the vibration output's zero-lag covariance matrix, under the assumption of broadband random excitation. A new metric is introduced, which expresses a certain part of the total stochastic vibration energy, and is attributed to each vibration mode. It is then shown how this metric can be integrated into a stabilization diagram, in order to enrich the displayed information and facilitate the model order selection process. In this respect, a vibration mode is identified as structural when it appears stabilized in both its frequency and its dispersion metric. The method's performance is assessed through structural identification problems from both simulated and experimental vibration data, for which subspace and prediction-error based methods are utilized.
0182.pdf (193.85 Ko) Télécharger le fichier
hal-01022975 , version 1 (11-07-2014)
  • HAL Id : hal-01022975 , version 1
Vasilis K. Dertimanis, Eleni Chatzi. Dispersion-Corrected Stabilization Diagrams for Model Order Assessment in Structural Identification. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022975⟩
118 Consultations
151 Téléchargements
