Quick reachability and proper extension for problems with unbounded controls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
For a CONTROL SYSTEM of the form _ x = f (x; u; v) + Σm =1 g (x)u_ ; on [0;T]; (x; u)(0) = ( x; u); with x : [0;T] ! IRn; u : [0;T] ! U IRm; v : [0;T] ! V IRl ; we rely on the notion of LIMIT SOLUTION, and we investigate whether minimum problems with L1controls are PROPER EXTENSIONS of regular problems with more regular controls (AC or BV). Motivation: optimality conditions, numerical methods, etc.
Aronna-NETCO.pdf (243.99 Ko) Télécharger le fichier
hal-01024111 , version 1 (15-07-2014)
  • HAL Id : hal-01024111 , version 1
Maria Soledad Aronna, Monica Motta, Franco Rampazzo. Quick reachability and proper extension for problems with unbounded controls. NETCO 2014, 2014, Tours, France. ⟨hal-01024111⟩
266 Consultations
76 Téléchargements
