Degenerate second order mean field games systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
We consider degenerate second order mean field games systems with a local coupling. The starting point is the idea that mean field games systems can be understood as an optimality condition for optimal control of PDEs. Developing this strategy for the degenerate second order case, we discuss the existence and uniqueness of a weak solution as well as its stability (vanishing viscosity limit). Speaker: Daniela TONON
Tonon-NetC02014.pdf (413.05 Ko) Télécharger le fichier
hal-01024600 , version 1 (18-07-2014)
  • HAL Id : hal-01024600 , version 1
Daniela Tonon, Pierre Cardaliaguet, Philip J. Graber, Alessio Porretta. Degenerate second order mean field games systems. NETCO 2014 - New Trends on Optimal Control, Jun 2014, Tours, France. ⟨hal-01024600⟩
336 Consultations
54 Téléchargements
