Complexity in control-affine systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
We will consider affine-control systems, i.e., systems in the form _ q(t) = f0(q(t)) + Xm i=1 ui (t)fi (q(t)) Here, the point q belongs to a smooth manifold M the fi 's are smooth vector fields on M u 2 L1([0;T];Rm) This type of system appears in many applications Mechanical systems Quantum control Microswimmers (Tucsnak, Alouges) Neuro-geometry of vision (Mumfor, Petitot)
Jean-NETCO2014.pdf (333.78 Ko) Télécharger le fichier
hal-01024628 , version 1 (17-07-2014)
  • HAL Id : hal-01024628 , version 1
Frédéric Jean, Dario Prandi. Complexity in control-affine systems. NETCO 2014, 2014, Tours, France. ⟨hal-01024628⟩
301 Consultations
63 Téléchargements
