Boosting bonsai trees for efficient features combination : application to speaker role identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article, we tackle the problem of speaker role detection from broadcast news shows. In the literature, many proposed solutions are based on the combination of various features coming from acoustic, lexical and semantic information with a machine learning algorithm. Many previous studies mention the use of boosting over decision stumps to combine efficiently these features. In this work, we propose a modification of this state-of-the-art machine learning algorithm changing the weak learner (decision stumps) by small decision trees, denoted bonsai trees. Experiments show that using bonsai trees as weak learners for the boosting algorithm largely improves both system error rate and learning time.
interspeech2014.pdf (237.43 Ko) Télécharger le fichier
hal-01025171 , version 1 (17-07-2014)
  • HAL Id : hal-01025171 , version 1
Antoine Laurent, Nathalie Camelin, Christian Raymond. Boosting bonsai trees for efficient features combination : application to speaker role identification. Interspeech, Sep 2014, Singapour, Singapore. ⟨hal-01025171⟩
699 Consultations
564 Téléchargements
