On the Optimization of Riemann-Stieltjes-Control-Systems with Application in Vehicle Dynamics
Optimizing discontinuous systems is a eld of research with many unsolved problems. In this work, we focus on a method to model dynamic multibody control systems subject to state dependent frictional impacts using Riemann- Stieltjes-Integrals. As the impulsive character of the system is based on the state only, the controls exclusively enter the continuous Riemannian part of the dynamics. The system equations are combined with a set of impact conditions, wich are introduced to calculate the jumps of generalized veloci- ties at contact using a formulation with energetically consistent generalized coe cients-of-restitution. These impact conditions are a reformulation of a complementarity problem with additional constraints on the post-impact ve- locities. Based on this model of di erential equations with state disconti- nuities, a gradient based optimization routine is presented making use of the bounded variation assumption in the velocity components. The veloc- ity jumps are computed by evaluatingthe frictional model as a minor op- timization problem for the coe cients-of-restitution in tangential direction. The theoretical method has shown to be applicable for di erent optimization problems with continuous state dependent cost functionals. The method is il- lustrated in a numerical example, where comfort and handling characteristics for vehicle models are optimized due to road irregularities. Last, we draw a comparison between results derived by this method and a commercial library for tyre-road interaction forces.
Optimisation et contrôle [math.OC]
Michael-NETCO2014.pdf (7.53 Mo)
Télécharger le fichier
ballVideo.avi (19.62 Mo)
quartercarVideo.avi (11.52 Mo)
viertelfahrzeug3.mpg (5.44 Mo)
Format : Vidéo
Format : Vidéo
Format : Vidéo
