3D direct and inverse solvers for eddy current testing of deposits in steam generator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We consider the inverse problem of estimating the shape profile of an unknown deposit from a set of eddy current impedance measurements. The measurements are acquired with an axial probe, which is modeled by a set of coils that generate a magnetic field inside the tube. For the direct problem, we validate the method that takes into account the tube support plates, highly conductive part, by a surface impedance condition. For the inverse problem, finite element and shape sensitivity analysis related to the eddy current problem are provided in order to determine the explicit formula of the gradient of a least square misfit functional. A geometrical-parametric shape inversion algorithm based on cylindrical coordinates is designed to improve the robustness and the quality of the reconstruction. Several numerical results are given in the experimental part. Numerical experiments on synthetic deposits, nearby or far away from the tube, with different shapes are considered in the axisymmetric configuration.
hal-01044648 , version 1 (24-07-2014)
Houssem Haddar, Mohamed Kamel Riahi. 3D direct and inverse solvers for eddy current testing of deposits in steam generator. [Research Report] INRIA Saclay - Equipe DeFI. 2014. ⟨hal-01044648⟩
370 Consultations
0 Téléchargements
