Deembedding of filters in multiplexers via rational approximation and interpolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a method to recover electrical parameters of filters embedded in a multiplexer for which scattering measurements are given. Unlike other approaches proposed for this problem, this method does not require a priori knowledge of the scattering parameters of the junction. This feature renders the procedure well suited for tuning purposes or for fault diagnosis. Technically the algorithm starts with a rational approximation step, in order to derive a rational representation of certain scattering parameters of the multiplexer. This representation is then used in a second step to identify the electrical model of each filter. This second step relies on a rational interpolation technique used to extract the filter's responses.
Seyfert_14_IMS_deembedding.pdf (370.59 Ko) Télécharger le fichier
hal-01052718 , version 1 (28-07-2014)
  • HAL Id : hal-01052718 , version 1
Fabien Seyfert, Matteo Oldoni, Martine Olivi, Sanda Lefteriu, Damien Pacaud. Deembedding of filters in multiplexers via rational approximation and interpolation. IMS - IEEE International Microwave Symposium, Jun 2014, Tampa Bay, Florida, United States. ⟨hal-01052718⟩
550 Consultations
275 Téléchargements
