Comparing Pedophile Activity in Different P2P Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Social Sciences Année : 2014
Matthieu Latapy
Isabelle Chrisment
Clémence Magnien
Ivan Daniloff
  • Fonction : Auteur
  • PersonId : 958893
Peer-to-peer (P2P) systems are widely used to exchange content over the Internet. Knowledge of pedophile activity in such networks remains limited, despite having important social consequences. Moreover, though there are different P2P systems in use, previous academic works on this topic focused on one system at a time and their results are not directly comparable. We design a methodology for comparing KAD and eDonkey, two P2P systems among the most prominent ones and with different anonymity levels. We monitor two eDonkey servers and the KAD network during several days and record hundreds of thousands of keyword-based queries. We detect pedophile-related queries with a previously validated tool and we propose, for the first time, a large-scale comparison of pedophile activity in two different P2P systems. We conclude that there are significantly fewer pedophile queries in KAD than in eDonkey (approximately 0.09% vs. 0.25%).
socsci-03-00314.pdf (260.19 Ko) Télécharger le fichier
hal-01052773 , version 1 (28-07-2014)
Raphaël Fournier, Thibault Cholez, Matthieu Latapy, Isabelle Chrisment, Clémence Magnien, et al.. Comparing Pedophile Activity in Different P2P Systems. Social Sciences, 2014, Special Issue on Contemporary Developments in Child Protection, 3 (3), pp.314-325. ⟨10.3390/socsci3030314⟩. ⟨hal-01052773⟩
551 Consultations
856 Téléchargements
