Combinatorial optimization in networks with Shared Risk Link Groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2016
The notion of Shared Risk Link Groups (SRLG) captures survivability issues when a set of links of a network may fail simultaneously. The theory of survivable network design relies on basic combinatorial objects that are rather easy to compute in the classical graph models: shortest paths, minimum cuts, or pairs of disjoint paths. In the SRLG context, the optimization criterion for these objects is no longer the number of edges they use, but the number of SRLGs involved. Unfortunately, computing these combinatorial objects is NP-hard and hard to approximate with this objective in general. Nevertheless some objects can be computed in polynomial time when the SRLGs satisfy certain structural properties of locality which correspond to practical ones, namely the star property (all links affected by a given SRLG are incident to a unique node) and the span 1 property (the links affected by a given SRLG form a connected component of the network). The star property is defined in a multi-colored model where a link can be affected by several SRLGs while the span property is defined only in a mono-colored model where a link can be affected by at most one SRLG. In this paper, we extend these notions to characterize new cases in which these optimization problems can be solved in polynomial time. We also investigate the computational impact of the transformation from the multi-colored model to the mono-colored one. Experimental results are presented to validate the proposed algorithms and principles.
dmtcs-1420.pdf (392.54 Ko) Télécharger le fichier
hal-01053859 , version 1 (02-08-2014)
hal-01053859 , version 2 (10-10-2015)
hal-01053859 , version 3 (29-03-2016)
hal-01053859 , version 4 (28-04-2016)
David Coudert, Stéphane Pérennes, Hervé Rivano, Marie-Emilie Voge. Combinatorial optimization in networks with Shared Risk Link Groups. Discrete Mathematics and Theoretical Computer Science, 2016, Vol. 18 no. 3 (3), pp.25. ⟨10.46298/dmtcs.1297⟩. ⟨hal-01053859v4⟩
1055 Consultations
1639 Téléchargements
