Fast Instruction Memory Hierarchy Power Exploration for Embedded Systems
A typical instruction memory design exploration
process using simulation tools for various cache parameters is a rather
time-consuming process, even for low complexity applications. In order
to design a power efficient memory hierarchy of an embedded system, a
huge number of system simulations are needed for all the different
instruction memory hierarchies, because many cache memory parameters
should be explored. Exhaustive search of design space using simulation
is too slow procedure and needs hundreds of simulations to find the
optimal cache configuration. This chapter provides fast and accurate
estimates of a multi-level instruction memory hierarchy. Using a detail
methodology for estimating the number of instruction cache misses of the
instruction cache levels and power models; we estimate within a
reasonable time the power consumption among these hierarchies. In order
to automate the estimation procedure, a novel software tool named FICA
implements the proposed methodology, which automatically estimates the
total energy in instruction memory hierarchy and reports the optimal
one.
Bibliothèque électronique [cs.DL]
