Novelty-Aware Attack Recognition - Intrusion Detection with Organic Computing Techniques
A typical task of intrusion detection systems is to detect known kinds of attacks by analyzing network traffic. In this article, we will take a step forward and enable such a system to recognize very new kinds of attacks by means of novelty-awareness mechanisms. That is, an intrusion detection system will be able to recognize deficits in its own knowledge and to react accordingly. It will present a learned rule premise to the system administrator which will then be labeled, i.e., extended by an appropriate conclusion. In this article, we present new techniques for novelty-aware attack recognition based on probabilistic rule modeling techniques and demonstrate how these techniques can successfully be applied to intrusion benchmark data. The proposed novelty-awareness techniques may also be used in other application fields by intelligent technical systems (e.g., organic computing systems) to resolve problems with knowledge deficits in a self-organizing way.
Bibliothèque électronique [cs.DL]
