Adaptation and Fatigue Model for Neuron Networks and Large Time Asymptotics in a Nonlinear Fragmentation Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Neuroscience Année : 2014
Motivated by a model for neural networks with adaptation and fatigue, we study a conservative fragmentation equation that describes the density probability of neurons with an elapsed time s after its last discharge.
In the linear setting, we extend an argument by Laurençot and Perthame to prove exponential decay to the steady state. This extension allows us to handle coefficients that have a large variation rather than constant coefficients. In another extension of the argument, we treat a weakly nonlinear case and prove total desynchronization in the network. For greater nonlinearities, we present a numerical study of the impact of the fragmentation term on the appearance of synchronization of neurons in the network using two "extreme" cases.
Mathematics Subject Classification (2000)2010: 35B40, 35F20, 35R09, 92B20.
2190-8567-4-14.pdf (447.81 Ko) Télécharger le fichier
2190-8567-4-14.xml (409.79 Ko) Télécharger le fichier
Format : Autre
hal-01054561 , version 1 (07-08-2014)
Khashayar Pakdaman, Benoît Perthame, Delphine Salort. Adaptation and Fatigue Model for Neuron Networks and Large Time Asymptotics in a Nonlinear Fragmentation Equation. Journal of Mathematical Neuroscience, 2014, 4 (1), pp.14. ⟨10.1186/2190-8567-4-14⟩. ⟨hal-01054561⟩
544 Consultations
161 Téléchargements
