Behavioural Contracts with Request-Response Operations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the context of service-oriented computing, behavioural contracts are abstract descriptions of the message-passing behaviour of services. They can be used to check properties of service compositions such as, for instance, client-service compliance. Previous formal models for contracts consider unidirectional send and receive operations. In this paper, we present two models for contracts with bidirectional request-response operations, in the presence of unboundedly many instances of both clients and servers. The first model takes inspiration from the abstract service interface language WSCL, the second one is inspired by Abstract WS-BPEL. We prove that client-service compliance is decidable in the former while it is undecidable in the latter, thus showing an interesting expressiveness gap between the modeling of request-response operations in WSCL and in Abstract WS-BPEL.
coordination10_9.pdf (163.64 Ko) Télécharger le fichier
hal-01054626 , version 1 (07-08-2014)
Paternité
Lucia Acciai, Michele Boreale, Gianluigi Zavattaro. Behavioural Contracts with Request-Response Operations. 12th International Conference on Coordination Models and Languages (COORDINATION) Held as part of International Federated Conference on Distributed Computing Techniques (DisCoTec), Jun 2010, Amsterdam, Netherlands. pp.16-30, ⟨10.1007/978-3-642-13414-2_2⟩. ⟨hal-01054626⟩
103 Consultations
96 Téléchargements
