Virtual Network Urbanization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Othmen Braham
  • Fonction : Auteur
Ahmed Amamou
  • Fonction : Auteur
Guy Pujolle
Adapting virtualization concepts to satisfy network telecommunication challenges receives more and more attention. The virtual network environment is formed by the amount of bounded virtual resources provided by physical network equipments. Deploying virtual network infrastructure has recently caught more research interests due to its flexibility and manageability. However, virtual network deployment is not evident as it should be. Therefore, it is now necessary to provide virtual environment design to coexist virtual networks and their respective operators. In this article, we describe our virtual network environment architecture. We explain the proposed organization strategies to improve virtual network urbanization. The initial results and quantitative analysis of the architecture deployment are exposed.
10-_Braham.pdf (193.42 Ko) Télécharger le fichier
hal-01054746 , version 1 (08-08-2014)
Othmen Braham, Ahmed Amamou, Guy Pujolle. Virtual Network Urbanization. NoF 2010 - 1st International Conference on the Network of the Future, Sep 2010, Brisbane, Australia. pp.182-193, ⟨10.1007/978-3-642-15476-8_18⟩. ⟨hal-01054746⟩
187 Consultations
191 Téléchargements
