Detecting Temporal Pattern and Cluster Changes in Social Networks: A Study Focusing UK Cattle Movement Database - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Temporal Data Mining is directed at the identification of knowledge that has some temporal dimension. This paper reports on work conducted to identify temporal frequent patterns in social network data. The focus for the work is the cattle movement database in operation in Great Britain, which can be interpreted as a social network with additional spatial and temporal information. The paper firstly proposes a trend mining framework for identifying frequent pattern trends. Experiments using this framework demonstrate that in many cases a large number of patterns may be produced, and consequently the analysis of the end result is inhibited. To assist in the analysis of the identified trends this paper secondly proposes a trend clustering approach, founded on the concept of Self Organizing Maps (SOMs), to group similar trends and to compare such groups. A distance function is used to compare and analyze the changes in clusters with respect to time.
Detecting_Temporal_Pattern_and_Cluster_Changes_in_Social_Networks_A_study_focusing_UK_Cattle_Movement_Database.pdf (470.17 Ko) Télécharger le fichier
hal-01055061 , version 1 (11-08-2014)
Paternité
Puteri N. E. Nohuddin, Frans Coenen, Rob Christley, Christian Setzkorn. Detecting Temporal Pattern and Cluster Changes in Social Networks: A Study Focusing UK Cattle Movement Database. 6th IFIP TC 12 International Conference on Intelligent Information Processing (IIP), Oct 2010, Manchester, United Kingdom. pp.163-172, ⟨10.1007/978-3-642-16327-2_22⟩. ⟨hal-01055061⟩
120 Consultations
184 Téléchargements
