Knowledge Granularity and Representation of Knowledge: Towards Knowledge Grid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Knowledge granularity, usually identified with the size of knowledge granules, seems to be real challenge for knowledge consumers as well as for knowledge creators. In this paper, relationships between knowledge granularity as a result of different ways of a knowledge representation are considered. The paper deals with the problem of developing knowledge grid in the context of encapsulation of knowledge including different dimensions and measures. The origin of the problem is discussed in the first section stressing flexibility of knowledge interpretations. Concepts of knowledge granularity (also from formal point of view) are presented in the next section. The nature of well represented knowledge is considered in the next chapter with references to granularity of knowledge. In the last part of the paper the question of formulating knowledge granularity in the context of knowledge grid concepts is discussed. This document comprising guidelines for authors is divided into several sections.
KNOWLEDGE_GRANULARITY_AND_REPRESENTATION_OF_KNOWLEDGE._TOWARDS_KNOWLEDGE_GRID.pdf (272.88 Ko) Télécharger le fichier
hal-01055071 , version 1 (11-08-2014)
Paternité
Maria A. Mach, Mieczyslaw L. Owoc. Knowledge Granularity and Representation of Knowledge: Towards Knowledge Grid. 6th IFIP TC 12 International Conference on Intelligent Information Processing (IIP), Oct 2010, Manchester, United Kingdom. pp.251-258, ⟨10.1007/978-3-642-16327-2_31⟩. ⟨hal-01055071⟩
131 Consultations
1035 Téléchargements
