A Domain Specific Language for Contextual Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tony Clark
  • Fonction : Auteur
  • PersonId : 944543
This paper examines the role of user-centered design (UCD) approaches to design and implementation of a mobile social software application to support student social workers in their work place. The experience of using a variant of UCD is outlined. The principles and expected norms of UCD raised a number of key lessons. It is proposed that these problems and lessons are a result of the inadequacy of precision of modeling the outcomes of UCD, which prevents model driven pproaches to method integration between UCD approaches. Given this, it is proposed that the Contextual Design method is a good candidate for enhancing with model driven principles. A subset of the Work model focussing on Cultural and Flow models are described using a domain specific language and supporting tool built using the MetaEdit+ platform.
Barn_Clark_Final.pdf (265.73 Ko) Télécharger le fichier
hal-01055231 , version 1 (11-08-2014)
Paternité
Balbir S. Barn, Tony Clark. A Domain Specific Language for Contextual Design. Third IFIP WG 13.2 International Conference on Human-Centred Software Engineering (HCSE), Oct 2010, Reykjavik, Iceland. pp.46-61, ⟨10.1007/978-3-642-16488-0_5⟩. ⟨hal-01055231⟩
83 Consultations
80 Téléchargements
