Testing Product Generation in Software Product Lines Using Pairwise for Features Coverage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A Software Product Lines (SPL) is "a set of software-intensive systems sharing a common, managed set of features that satisfy the specific needs of a particular market segment or mission and that are developed from a common set of core assets in a prescribed way". Variability is a central concept that permits the generation of different products of the family by reusing core assets. It is captured through features which, for a SPL, define its scope. Features are represented in a feature model, which is later used to generate the products from the line. From the testing point of view, testing all the possible combinations in feature models is not practical because: (1) the number of possible combinations (i.e., combinations of features for composing products) may be untreatable, and (2) some combinations may contain incompatible features. Thus, this paper resolves the problem by the implementation of combinatorial testing techniques adapted to the SPL context.
64350110.pdf (5.41 Mo) Télécharger le fichier
hal-01055240 , version 1 (12-08-2014)
Paternité
Beatriz Pérez Lamancha, Macario Polo Usaola. Testing Product Generation in Software Product Lines Using Pairwise for Features Coverage. 22nd IFIP WG 6.1 International Conference on Testing Software and Systems (ICTSS), Nov 2010, Natal, Brazil. pp.111-125, ⟨10.1007/978-3-642-16573-3_9⟩. ⟨hal-01055240⟩
89 Consultations
232 Téléchargements
