A Learning-based Approach to Unit Testing of Numerical Software - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an application of learning-based testing to the problem of automated test case generation (ATCG) for numerical software. Our approach uses n-dimensional polynomial models as an algorithmically learned abstraction of the SUT which supports n-wise testing. Test cases are iteratively generated by applying a satisfiability algorithm to first-order program specifications over real closed fields and iteratively refined piecewise polynomial models. We benchmark the performance of our iterative ATCG algorithm against iterative random testing, and empirically analyse its performance in finding injected errors in numerical codes. Our results show that for software with small errors, or long mean time to failure, learning-based testing is increasingly more efficient than iterative random testing.
64350220.pdf (855.41 Ko) Télécharger le fichier
hal-01055250 , version 1 (12-08-2014)
Paternité
Karl Meinke, Fei Niu. A Learning-based Approach to Unit Testing of Numerical Software. 22nd IFIP WG 6.1 International Conference on Testing Software and Systems (ICTSS), Nov 2010, Natal, Brazil. pp.221-235, ⟨10.1007/978-3-642-16573-3_16⟩. ⟨hal-01055250⟩
134 Consultations
364 Téléchargements
