Seeding Element Polarity Arrangement on Drum-Type Magnetic Precision Seeder
In order to improve Multi-polar magnetic structure's
efficiency. Ansoft Maxwell of electromagnetic field finite element
software is utilized to study the effect of different polarity
arrangement of magnetic seeding element on the magnetic induction
intensity of seeding element end and magnetic field distribution in the
seeding air gap. As a result of the different electromagnetic coil
current direction, magnetic polarity side is different, space structure
of magnetic field distribution is also different. The suction metering
device of the scope and efficiency is decided by the magnetic field
distribution. According to the results of finite element analysis of
magnetic field, research on magnetic drum seed-metering device with the
design of the program components, and enhance the precision seed
metering device performance. Studies have shown that the magnetic
induction intensity of seeder in the same polarity arrangement such as
NN or SS is lower than in the arrangement of cross with NS, and magnetic
field is uniform along the circumference and non- uniform along the
axial in the both the arrangement.
