Digital Modeling and Testing Research on Digging Mechanism of Deep Rootstalk Crops
The digital model of the laboratory bench parts of
digging deep rootstalk crops were established through adopting the
parametric model technology based on feature. The virtual assembly of
the laboratory bench of digging deep rootstalk crops was done and the
digital model of the laboratory bench parts of digging deep rootstalk
crops was gained. The vibrospade, which is the key part of the
laboratory bench of digging deep rootstalk crops was simulated and the
movement parametric curves of spear on the vibrospade were obtained. The
results show that the spear was accorded with design requirements. It is
propitious to the deep rootstalk.
