Eye Contact Communication System between Mobile Robots Using Invisible Code Display
The authors have been developing the mobile robots
which can cooperation between robots. The robots should communicate with
each other in order to cooperate together. Therefore, the inter
communication between robots is very important problem to be solved.
These robots generally utilize wireless transmission system. The
transmission sets send and receive on the same frequency or channel to
establish the radio communication. This is called working simplex. The
robots cannot start communication if both sets use different frequency
channels. It is important to perform an initial configuration for
establishing the radio signal transmission at a first contact among
strange mobile robots. To solve this problem, this paper describes an
information transmission system using an invisible code on displays
which show an expression of robot's eyes.
