Defining Tolerances in Assembly Process with the Aid of Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Analysis and allocation of tolerance are the typical problems in tolerance planning for the assembly and its components. This paper presents the developed simulator which is able to assist in solving tolerance planning problems in production processes, both in manufacturing and assembly processes. The paper also shows the benefits of this simulator which leads to quality characterisation and improvement, cost reduction and shorter design and planning phases.
Paper_10_-_CROSTACK_REFFLINGHAUS.pdf (274 Ko) Télécharger le fichier
hal-01055665 , version 1 (13-08-2014)
Paternité
H. -A. Crostack, R. Refflinghaus, Jirapha Liangsiri. Defining Tolerances in Assembly Process with the Aid of Simulation. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.33-40, ⟨10.1007/978-3-642-11598-1_4⟩. ⟨hal-01055665⟩
96 Consultations
1773 Téléchargements
