Development of a Reconfigurable Fixture for the Automated Assembly and Disassembly of High Pressure Rotors for Rolls-Royce Aero Engines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes a novel fixturing system for the automated assembly and disassembly of aero engine components. The proposed system has the ability to automatically reconfigure for a number of different parts and allows the precise control and monitoring of its clamping positions and exerted clamping forces. Aspects of the control software of this system, like the graphical user interface (GUI) and the relational data base system containing post-process and configuration data, are described.
Paper_35_-_PAPASTATHIS.pdf (703.57 Ko) Télécharger le fichier
hal-01055673 , version 1 (13-08-2014)
Paternité
Thomas Papastathis, Marco Ryll, Stuart Bone, Svetan Ratchev. Development of a Reconfigurable Fixture for the Automated Assembly and Disassembly of High Pressure Rotors for Rolls-Royce Aero Engines. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.283-289, ⟨10.1007/978-3-642-11598-1_33⟩. ⟨hal-01055673⟩
161 Consultations
422 Téléchargements
