Flexure-Based 6-Axis Alignment Module for Automated Laser Assembly
Fully automating the assembly of laser systems puts
high demands on the accuracy, but alike on the flexibility and
adaptivity of the assembly system. In this paper a concept for a
flexible robot-based precision assembly is introduced. This concept is
based on a modular 6-axis alignment tool which has been designed as a
hybrid serial-parallel manipulator with flexures for all revolute and
spherical joints. Technical insights on the design and dimensioning
based on analytical calculations will be presented as well as first
results from the characterization of a prototypal alignment
module.
