Vision and Force Sensing to Decrease Assembly Uncertainty
This paper presents two ways of decreasing the
assembly uncertainty of micro assembly tasks through further or
optimized integration of sensors within a size adapted assembly system.
To accomplish this, the orientation of the part to be placed with
respect to the vision sensor is changed. This was possible through a new
gripper which was able to overcome the restrictions placed on the system
by the vision sensor. Another increase in precision was obtained through
the integration of a force sensor into the wrist of the robot. This
force sensor provides additional information about the placing process
which allows the maximal force in the vertical axis to be limited. These
improvements are then demonstrated on a task which requires the
placement of linear guides which are 8.4 millimeters by 1
millimeter.
Bibliothèque électronique [cs.DL]
