Development of Manufacture Support System Using Taguchi Methods
A Manufacture Support System using Taguchi Methods was developed and evaluated. This system consists of a Taguchi methods part, a CAE simulation part and a management part of productivity. The Taguchi methods part was firstly used for calculating the average and the standard deviation regarding all combinations using all parameters. The CAE part was then used for shortening the total time of evaluation. The management part of productivity was finally used to select the optimum combination of all parameters for success percentage, accuracy, manufacturing time and total cost. The spring back of warm press forming on magnesium alloy plate was investigated for evaluating this system. It is concluded from the result that (1) This method effectively predicted optimum process conditions in each priority and (2) The predicted results conformed to the results of the spring back test.
