Methodology of Designing Disassembly and Reassembly Processes Using Lean Thinking Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a conception of using Lean Manufacturing methodology in disassembly and reassembly processes (Remanufacturing) is presented. Nine scenarios of material and information flows in Remanufacturing processes were developed in order to cover most of possible real situations.
03380009.pdf (106.06 Ko) Télécharger le fichier
hal-01055848 , version 1 (13-08-2014)
Paternité
Tomasz Kanikuła, Tomasz Koch. Methodology of Designing Disassembly and Reassembly Processes Using Lean Thinking Approach. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.11-18, ⟨10.1007/978-3-642-16358-6_2⟩. ⟨hal-01055848⟩
303 Consultations
334 Téléchargements
