The Impact of Behavior-Based Strategies on Supply Uncertainty - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Today's economical environment encompasses a high level of uncertainty, which affects decision makers capability in predicting future events, their occurrence probability and possible decision outcomes. A common way to guard against uncertainty is holding inventory in order to ensuring business continuity and on-time delivery to customer, buffering the effect of the risk. This method belongs to the buffer-oriented techniques that represent only a shield against uncertainty and contribute to raise the overall costs. A more effective way to reduce supply uncertainty is to deeply analyze its sources and try to reduce its occurrence probability adopting behavior-based strategies. A Systems Thinking model, aiming at explaining the logical relationships among different strategies and at analyzing their impact on supply uncertainty and total costs, is presented.
03380135.pdf (365.25 Ko) Télécharger le fichier
hal-01055859 , version 1 (13-08-2014)
Paternité
Pirola Fabiana, Pinto Roberto. The Impact of Behavior-Based Strategies on Supply Uncertainty. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.136-143, ⟨10.1007/978-3-642-16358-6_18⟩. ⟨hal-01055859⟩
121 Consultations
105 Téléchargements
