Collaborative Design System for Supporting Dynamic Virtual Enterprises - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Collaborative design provides creative design solutions and improves product quality as well as enriches participants' knowledge. Nevertheless, design and supply chain integration in product development processes is not a trivial task. The complex scenario of the dynamic extended enterprise triggers research toward the development of an innovative co-design platform to support multidisciplinary workgroups. Starting from the definition of a new design process model, the proposed approach is based on the formalization of the distributed knowledge in terms of interaction rules and representational models.
pro69.pdf (503.49 Ko) Télécharger le fichier
hal-01055944 , version 1 (25-08-2014)
Paternité
Michele Germani, Marco Mandolini, Maura Mengoni, Margherita Peruzzini. Collaborative Design System for Supporting Dynamic Virtual Enterprises. 11th IFIP WG 5.5 Working Conference on Virtual Enterprises (PRO-VE), Oct 2010, Saint-Etienne, France. pp.577-584, ⟨10.1007/978-3-642-15961-9_69⟩. ⟨hal-01055944⟩
46 Consultations
117 Téléchargements
