A Collaborative Decision Support Method to Design Performance Evaluation Systems in CNOs
This paper describes an approach to the design of performance management models in collaborative networks, from a constructivist approach. The general approach is outlined and the part concerning a multi-criteria decision support method is explained. The paper finishes with an illustration of a scenario for test and validation of the method.
