Lightweight Process Modeling for Virtual Enterprise Process Collaboration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mashup is a new web 2.0 technology for data aggregation applications, combining data from different sources to create valuable information. The uses of mashups are often more data related than process related. In this paper, we explore the differences between data-oriented mashups and process-oriented enterprise mashups and consider how process mashups can be used for virtual enterprise collaboration. We highlight the modeling of end users' process mashup applications from both a control flow and a data flow perspective. Based on our analyses, a lightweight process modeling approach is proposed for process enterprise mashup applications. Our approach, illustrated by reference to an example personal collaborative activity, will support collaboration among users with different levels of modeling skills and expertise in a virtual enterprise environment.
pro60.pdf (110 Ko) Télécharger le fichier
hal-01055953 , version 1 (25-08-2014)
Paternité
Lai Xu, Paul de Vrieze, Keith Phalp, Sheridan Jeary, Peng Liang. Lightweight Process Modeling for Virtual Enterprise Process Collaboration. 11th IFIP WG 5.5 Working Conference on Virtual Enterprises (PRO-VE), Oct 2010, Saint-Etienne, France. pp.501-508, ⟨10.1007/978-3-642-15961-9_60⟩. ⟨hal-01055953⟩
141 Consultations
254 Téléchargements
