Pro-Active Service Entity Framework for a Better Mapping between Business and Software
The service concept is widely used in distinct research and application areas. Particularly in Collaborative Networks, Service Orientation represents a main trend in the development of support platforms. Nevertheless, a literature review shows that it does not gather a common understanding, namely from the software and business perspectives. This paper proposes a conceptual framework aiming at contributing to make these two perspectives come closer, through a refinement of the Service concept itself and the usage of Pro-Activeness.
Bibliothèque électronique [cs.DL]
