Towards a Reference Mission Map for Performance Measurement in Humanitarian Supply Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Research on performance measurement in humanitarian supply chains is scant. Experiences with developing performance measures in commercial environments show that it is particularly important to understand linkages between higher level goals and performance measurement, for example through using strategy maps in for-profit organisations or mission maps in non-profit organisations. In this article, we use literature and four mini-case studies in humanitarian organisations to develop a reference mission map for a humanitarian supply chain. This reference mission map may be used by humanitarian organisations to develop an organisation specific mission map for their supply chain.
pro21.pdf (106.5 Ko) Télécharger le fichier
hal-01055994 , version 1 (25-08-2014)
Paternité
Sander de Leeuw. Towards a Reference Mission Map for Performance Measurement in Humanitarian Supply Chains. 11th IFIP WG 5.5 Working Conference on Virtual Enterprises (PRO-VE), Oct 2010, Saint-Etienne, France. pp.181-188, ⟨10.1007/978-3-642-15961-9_21⟩. ⟨hal-01055994⟩
164 Consultations
297 Téléchargements
