Introducing Automated Unit Testing into Open Source Projects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To learn how to introduce automated unit testing into existing medium scale Open Source projects, a long-term field experiment was performed with the Open Source project FreeCol. Results indicate that (1) introducing testing is both beneficial to the project and feasible for an outside innovator, (2) testing can enhance communication between developers, (3) an active stance is important for engaging the project participants to fill a newly vacant position left by a withdrawal of the innovator.
00-testing-intro-main.pdf (268.82 Ko) Télécharger le fichier
hal-01056039 , version 1 (14-08-2014)
Paternité
Christopher Oezbek. Introducing Automated Unit Testing into Open Source Projects. 6th International IFIP WG 2.13 Conference on Open Source Systems,(OSS), May 2010, Notre Dame, United States. pp.361-366, ⟨10.1007/978-3-642-13244-5_32⟩. ⟨hal-01056039⟩
47 Consultations
360 Téléchargements
